It is currently Mon Jul 21, 2025 4:46 am
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jan 21, 2007 2:51 am
Can't buy Everclear in NY state, so I got a gallon of 190 proof grain alc from a local herbalist who uses it to make tinctures. He has a permit to buy it and gets it in quantities of 20 gal or more. Make friends with your local herbalists and you may have a great source of pure grain alcohol. Less $$$ than Everclear, same stuff.
Though I use all sorts of solvents in my shop when necessary, I still try to limit my inhalation of toxic vapors as much as possible, so I avoid DA (I do have some, and use it occasionally).
If the Brune's assertion of the added solvents in DA dissolving some wax and making a softer finish is correct (sounds plausible to me, and I have no reason to doubt their research on it), there's another good reason for using pure grain alc. Unless you want a softer finish.
Todd Rose
Ithaca, NY
PostPosted: Sun Jan 21, 2007 9:45 am
DA's not a problem if you use de-waxed shellac flakes (or ZInser/Liberon pre-mixed).
PostPosted: Mon Jan 22, 2007 10:59 am
[QUOTE=rich altieri] ...then off to find some walnut oil and give this a try.[/QUOTE]
Make sure it contains no additives. Some of the grocery-store varieties do. Lee Valley and, I think, Woodcraft have pure walnut oil.
PostPosted: Tue Jan 23, 2007 6:25 am
[QUOTE=Hesh1956] I used the Wood craft walnut oil in my salad tonight........ [/QUOTE]
Well, okay...but don't use hide glue as a skin tightener, or fish glue as a cologne.
